Bobrik написав:Этот набор раньше дружил друг с другом? Как по мне, ДМРВ или не тот или не работает.
Судя по этой табличке то у них свадьба была с завада
etronic Version Bosch AMM part # Bosch ECU
Part # Engine 240 years 740 years 940 years Acceptable substitutes
LH 1.0? ? 0 280 000-500 - 1982 - - -
LH 2.0 -002 0 280 000-503 B23F 1983-1984 - - -
LH 2.0 -002 0 280 000-507(?) B23FT 1982-1984 1983-1984 - -
LH 2.2 -007(?) 0 280 000-511 B230F 1985-1988 1985-1988 - -
LH 2.2 -007 0 280 000-541 B230FT - 1987-1989 (turbo)
1987-1989 (760)
1989 (780) - -
LH 2.2 -007 0 280 000-544 B230F 1985-1988 8/1984-7/1987 - -541, -544, -554
LH 2.2 -007 0 280 000-554 B230F 1988 8/1987-7/1988 - -541, -544, -554
LH 2.4 -016 0 280 000-556 B230FD 1989 (EGR) 1989-1990 (EGR) - California / EGR Model: -937, -967 and -954 are suitable.
LH 2.4 -016 0 280 000-560 B230FT - - 1990-1991 (turbo)(egr) -563; -967(?)
LH 2.4 -016 0 280 000-561 B230F 1989-1992(?) 1989-1990 - Pink label models problematic. White label 561 less problem prone.
-933, -935 and -951 known good subsitutions.
LH 2.4 -016 0 280 000-562 B234F - 1991 (16 valve) - -928
LH 2.4 -016 0 280 000-563 B230FT - 8/1989-7/1991 turbo
8/1989-07/1991 (760 Turbo)
1990-1992 (780) 1991 (turbo) -937, -939, -954, -962, -975, -976, -977 should all be compatible with B230FT engine setups.
LH 2.4 -016 0 280 000-571 B234F - ? - 1991 (16 valve) - -928
LH3.1 -001, 4-pin 0 280 000-572 B230F 1990-1992 - - May have also been installed in 1993 240s.
LH 2.4 -016(?) 0 280 000-911 B230G - 1991(?) 1991(?) -
LH 2.4 -016 0 280 000-928 B234F - 1991-1992 (16 valve) - -
LH 2.4 -016(?) 0 280 000-930 B230G - 1992(?) 1992(?) -
LH 2.4 -016 0 280 000-933 B230F - 1991-1992 (EGR?) California-spec turbo models(?) Eliminated use of cold start injector.
LH 2.4 -016 0 280 000-935 B230F - - 6/1991-8/1995 -
LH 2.4 -016 0 280 000-937 B230FT - 1991-1992(?) (turbo) 1992-1993 (turbo) Should work in 8-valve non-turbo.
LH 2.4 -016 0 280 000-939 B230F - - 1992 -
LH 2.4 -016 0 280 000-943 B230FD 1993(EGR?) - 1994(?)-1995 -946. Should work for EGR and non-EGR models.
LH 2.4 -016 0 280 000-946 B230FD 1993(EGR?) - 1991-1995 NA -
LH 2.4 -016 0 280 000-951 B230F 1993 - - Good substitute for non-turbo, non-EGR LH2.4 ECUs above. Eliminated use of cold start injector.
LH 2.4 -016 0 280 000-954 B230FT, B230FK - - 1995 (turbo) Should work in non-turbo, non-EGR models.
LH 2.4 -016 0 280-000-962 B230FT - - 1994 (turbo) Possibly for EGR models(?)
LH 2.4 -016 0 280-000-967 B230FT - - 1993-1994 (turbo) -
LH 2.4 -016 0 280-000-975 B230FT, B230FK - - 1995 (turbo) -
LH 2.4 -016 0 280-000-976 B230FT, B230FK - - 1996 (turbo) Uncertain if with EGR or without.
LH 2.4 -016 0 280-000-977 B230FT, B230FK - - 1996 (turbo) Uncertain if with EGR or without.
LH 2.4 -016 0 280-000-984 B230ET - - 1997-1998 (Euro) Reputed to be the best LH2.4 Turbo ECU.
